Richnew41 | Hi all, New Prowler in the garage (1k miles)… Gave her the once over and came across a small but irritating issue… Only on the drivers door when you open it, the bell alarm goes off ( same alarm sound when the back trunk is not closed). Goes off after the door is closed but as soon as it’s opened, it’s back on… Any ideas? Thanks Rich |
ALLEY CAT | Check the headlight switch to be sure its 100% push-in tight. If that bezel is loose or cracked, the switch may not be 100% pushed-in? Mine did that once, and when the driver's door was opened the alarm was telling me 'something else' needs attention. That is what I found, but it maybe another thing causing the alarm to sound. Good luck,,,,, tell us what you find was the answer! ------------------
This message has been edited by ALLEY CAT on 02-16-2024 at 04:46 PM |
ALLEY CAT | Sorry,,,, double loaf,,double post ... This message has been edited by ALLEY CAT on 02-16-2024 at 04:47 PM |
Richnew41 | Good call!!!! It was the light switch just as you said…. Lights were off but seemed to be stuck from going all the way in… worked it a few times in and out and the alarm stopped… Problem solved and thank you so much! |
ALLEY CAT | Thanks for reporting back Rich,,,that that was the issue causing the alarm to sound. If that nickel-size bezel part has been unattached from the dash,,,you might want to put a drop of adhesive on it's back side to reattach and prevent the alarm from sounding again. Glad I could help out! ------------------
